How to Apply Preset to project from RemoteDesk dashboard
Definition Of Preset:
A preset in RemoteDesk is a predefined configuration or set of parameters that can be applied to a project or task within the RemoteDesk platform. It includes various settings related to project setup, user permissions, monitoring preferences, and security measures. By utilizing presets, RemoteDesk users can quickly apply standardized configurations to new projects, ensuring consistency and efficiency in managing remote workforce activities. Presets streamline the setup process, reduce manual configuration efforts, and help maintain compliance with organizational policies and industry standards.
Applying a Preset to a New Project in RemoteDesk
1. Navigate to the Project list and locate the project to which you wish to apply the preset. Click on the three dots (...) next to the project and select the "Edit" option.
2. Within the project settings, locate the "Preset" option.
3. Click on "Preset" to access the Preset list.
4. Choose the desired preset from the available list.
5. After selecting the preset, click on the "Apply Preset" button.
6. Once the preset is applied, click on the "Save" button to confirm the changes.
7. Great!! The preset settings have now been successfully applied to the selected project.
